Breakthrough acceleration that doesn’t break budgets
Enabling a green, fair, trusted and safe world.
Metis® AIPU
Currently, artificial intelligence (AI) technology has primarily been designed for cloud computing operations, which do not have the same cost, power and scalability constraints as edge devices. The hardware for edge applications requires an entirely new design considering specific computational performance, power, and economic conditions.
We are creating the future of Edge AI with industry-leading performance, usability, and efficiency at a fraction of the cost of existing solutions.
Meet the Metis architecture. Optimized for inference in embedded and edge systems, with scalable technology to meet the future demands of AI acceleration workloads.
AI performance
The world is more interconnected now than ever before. Yet, 98% of the data being collected remains unused due to technology and processing limitations. Bridging this data gap requires a new generation of more powerful, efficient, and accessible computation hardware. By delivering class leading compute density that results up to 214 TOPs from a single Metis AI processing unit, Axelera® AI solutions meet this demand, empowering AI applications at the Edge.
Up to 214 TOPs @ INT8
Up to 3200frames per second (ResNet-50)
15 TOPs/W – class leading energy efficiency
Performance, Efficiency, Accuracy: Verified by Third-Party Testing
HotTech Vision & Analysis, put leading AI accelerators to the test. Axelera Metis came out on top with the fastest performance, best efficiency, and highest detection accuracy across real-world computer vision workloads.
Usability
Artificial intelligence has the potential to positively change the world and support humanity in ways we have yet to even consider. However, the complexity of mastering AI can be challenging, for end-users as well as system integrators and developers. By creating integrated solutions that are easy to implement and use, Axelera AI is simplifying AI at the Edge. Not just delivering raw compute performance but doing so accurately and efficiently. We are also going beyond just the accelerator technology and looking to build a fully interconnected ecosystem of support.
Our software platform, Voyager® SDK, makes it easy to build high-performance AI applications.
Fully compatible and scalable - no need to retrain
Scalable solution with multiple Metis AIPUs
Minimal Power
Power consumption is a critical factor when it comes to Edge applications, and for many applications will only have limited power budgets. So Axelera AI offers class leading compute density with exceptional core efficiency. The result means systems can easily crunch data without draining power or running hot, with a typical use case requiring just a few Watts. Tackling the Compute Energy vs. Global Energy Production challenge head-on.
Delivers 15 TOPs/W efficiency
Typical power consumption of 10W
Industry-Leading FPS / Watt ratios on ResNet50v1
Edge price point
Until now AI systems and applications have relied on the computational performance of large, power hungry and expensive hardware. However, fully unlocking the potential of AI, especially at the Edge, requires a dramatic increase in FPS/$ which will enable complex AI applications to run on-device at the Edge. Running the industry-standard benchmark of ResNet50v1, the Metis PCIe system can achieve a record-breaking 16.4 fps/$, which truly is breakthrough AI acceleration.
