AI SOFTWARE
Voyager Toolkit
Everything you need to build, faster
The Voyager® SDK gives developers a complete path from model to deployment on Axelera hardware. Axelera Wingman, our AI coding agent, simplifies development even more, building pipelines, finding answers, and debugging code on prompt.
End-to-end integrated software stack
Purpose-built for AI inference, the Voyager SDK moves you from idea to deployment quickly, with deep customization when you need it. It supports applications built on proprietary or standard industry models, and its end-to-end integration and API compatibility with de-facto industry standards mean high-performance AI on Axelera hardware, without the slowdown.
Voyager SDK is available for download on our Docs Portal.
Voyager SDK Horizontal Color Logo
Optimized deployment
The Voyager SDK makes it easy to build high-performance AI applications. You describe your end-to-end pipeline in YAML, a simple, human-readable, high-level declarative language, and the SDK takes care of the rest. With Voyager SDK, you can:
  • Define complete pipelines in YAML, including one or more neural networks, plus their pre/post-processing tasks, which can include sophisticated image processing operations
  • Skip the manual optimization work. The SDK automatically compiles, optimizes, and deploys your entire pipeline, making use of host processors (CPU, embedded GPU, or media accelerator) and AIPU as required
  • Build across a wide range of host architectures and platforms to meet the requirements of diverse application environments
  • Go from pipeline to solution fast. Flexibly embed a pipeline into an inference service to get a variety of preconfigured, out-of-the-box solutions, from single-stream use cases to distributed processing of multiple 4K streams
Customer models   Model zoo   Non-neural libraries
Low-code deployment flow
Gstreamer   TVM compiler
(PyTorch, TF, ONNX)
  Open CL/GL compiler
Pipeline Callback API
Customer application   Inference server
Metis runtime
PCIe
Ethernet
Metis hardware
An AI coding agent that's fine-tuned for Axelera hardware
Axelera Wingman has deep knowledge of our SDK and documentation, for developers who want to build production-grade solutions faster. It builds, debugs, and optimizes AI inferencing pipelines using natural language inputs for 20 to 30% higher accuracy than general-purpose AI coding tools.
Every developer needs a wingman.
wordmark-master
Expert Assistance
  • Build end-to-end applications. Describe the pipeline you want, from a single model to a multi-stage cascade, and get a working result while preserving accuracy.
  • Optimize performance. Get concrete recommendations on compiler configurations and how to get the most out of Axelera hardware.
  • Debug faster. Diagnose configuration errors, device enumeration issues, and models that fail to compile, with guidance toward a working result.
  • Get documentation on demand. Ask about supported operators, APIs, and runtime behavior, and get contextual answers with examples instead of searching reference docs.
Available as a web-based chat and a standalone app, with a plugin for popular AI coding frameworks coming soon. Its knowledge updates automatically with every Voyager SDK release, so there's nothing to download or maintain.
Try Axelera Wingman free through the Axelera Developer Community with a starter credit allowance, or use the app at no cost with your own API key.
Wingman Expertise Assitance Image
See Axelera Wingman in Action
Introducing Axelera Wingman by Axelera AI
Welcome to the future of AI engineering. In this video, Steven Hunsche (Senior AI Solutions Engineer) introduces Axelera Wingman, an innovative application designed to automatically create end-to-end AI pipelines for Axelera hardware. By mapping and understanding Axelera's entire codebase, Wingman works alongside LLMs like Claude and ChatGPT to design, build, and test custom pipelines in minutes—no deep machine learning expertise required. This is true "vibe coding" brought to life.
How to Build a Soccer CV Analytics App in Minutes with Axelera Wingman!
Axelera Wingman builds a real-time soccer broadcast console with computer vision, just from a prompt. No pipeline code from scratch: Wingman generates the full workflow using the Voyager SDK and Axelera's documentation, getting max hardware performance in minutes, not hours.
Track player velocity, map tactical heatmaps, or analyze key moments from Dallas, Atlanta, or MetLife Stadium; Voyager Wingman makes it seamless.
Build a Real-Time Endoscopy AI Analyzer with Axelera Wingman
Axelera Wingman builds a real-time endoscopic video analysis pipeline for the edge, just from a prompt. No manual coding, no driver debugging, no model tuning: fully optimized, hardware-accelerated code in minutes, using the Voyager SDK and Axelera's hardware knowledge.
AI acceleration at the medical edge, without the software bottleneck.
